05 Accord AC Problem
Old Jun 13, 2015 | 10:41 PM
  #31
TxRzrBk's Avatar
I've located a used ECU (same part number). What is a ballpark figure for the dealer to reprogram the immobilizer and make my current keys work?
Old Jun 14, 2015 | 09:42 AM
  #32
I had a Acura TSX new key (spare) cut and programmed for $50. Note that does not include key cost, which was about $50. I also had an price of $175 to provide key and program by local locksmith. Check around, I think even Walmart does some smart keys.
Suggest carefully reading the shop manual instructions and precautions on removing ECM/PCM and installing a replacement ECM/PCM.
Old Jun 14, 2015 | 11:43 AM
  #33
TxRzrBk's Avatar
I thought the dealer would program the ecu to match the current keys? As far as changing the ecu, I don't have the manual but assumed it would be safe with the battery disconnected , then hit the brakes a couple times to make sure there is no residual power and swap.
Old Jun 18, 2015 | 06:20 PM
  #34
TxRzrBk's Avatar
I installed the ecu and got it programmed at the dealer, the ac is now working although it is a hair low on charge. Many thanks for all of the advise, I wouldn't have been able to figure it out otherwise.
Old Jun 18, 2015 | 06:38 PM
  #35
Thanks for reporting outcome.
What did dealer charge to program PCM to accept your keys?
Old Jun 19, 2015 | 07:49 AM
  #36
TxRzrBk's Avatar
I called a few and ended up finding a dealer who did it for $110.
trouble
Aug 21, 2012 07:46 PM
jkrueger2020
Mar 10, 2011 02:18 AM
kellysa111
May 1, 2009 08:35 AM
mahones
Oct 13, 2008 08:24 AM
92Inspire
Aug 13, 2006 03:37 PM
