1990 accord help plz need help bad
Old Jan 14, 2010 | 10:12 AM
That sideways play is the REAL problem why it keeps breaking rotors. You need a new distributor (bad shaft bearing).
Best is to use a timing light to properly adjust your spark timing with your new distributor. Probably sorta OK to mark it well & put the new one in the same position. Got a timing light? Setting your spark timing isn't that difficult.
Old Jan 14, 2010 | 10:18 AM
90accord90's Avatar
Thank you jimblake you been help im hopefuly getting a new or used one today and hopefuly it will start once i change the distributor... i dont have a timing light but i might be able to borrow one from a few friends.....
Old Jan 14, 2010 | 12:18 PM
A timing light is a good tool to have if you keep working on cars.
About the PM friend request - no offense, but I'd rather solve things here in the forum. The whole idea is for other people to see this when THEY come across the same problem.
Old Jan 14, 2010 | 05:23 PM
90accord90's Avatar
Its okay i like that idea.... okay well my car is now alive woot woot im happy now lol... i got a distributor from an h22 honda vtec it fit right in and with some timeing it started right up..... but...... now it seems to run slugish and slow on take off. The check engine light comes on now when i seem to get on it a little around 40mph and it when i turn my car off and back on its gone.... then it smelled like my cat was going but it has already been gone since iv had the car..... so can anyone tell me how to get it run back to normal....
Old Jan 14, 2010 | 06:08 PM
Since your check engine light turned on, you should get the code.
Even when the check engine light turns off, the computer will store that code for a while, so you can retrieve it.
Old Jan 16, 2010 | 12:18 AM
90accord90's Avatar
okay thanks.... so would that be why its running slugish....
Old Jan 16, 2010 | 06:01 PM
  #17
kris_loehr's Avatar
I am betting your dist. has a worn bushing and that is your starting problem as the rotor is tearing up the cap contacts or is too far away from them depending on where the shaft places the rotor(it has to line up with the button in the center of the cap and the contact for each cylinders. I have never bought a dist for an Accord so I don’t know if you have to reuse any parts but it is easy to remove and replace. If you install it correctly it should slide right in if not you have the shaft a 180 degrees off. You should set the timing when you are done. On my Accord there is a jumper below the grove compartment you jump and then set the base timing.
Let us know how it turns out
italiangirl5150
Feb 22, 2015 03:02 AM
pakalolo
Oct 28, 2013 02:06 PM
giulio76
Dec 29, 2012 11:16 AM
haroldyray
Jan 31, 2012 02:12 AM
inmate1981
Oct 1, 2009 10:10 AM
