1990 accord help plz need help bad
That sideways play is the REAL problem why it keeps breaking rotors. You need a new distributor (bad shaft bearing).
Best is to use a timing light to properly adjust your spark timing with your new distributor. Probably sorta OK to mark it well & put the new one in the same position. Got a timing light? Setting your spark timing isn't that difficult.
Thank you jimblake you been help im hopefuly getting a new or used one today and hopefuly it will start once i change the distributor... i dont have a timing light but i might be able to borrow one from a few friends.....
A timing light is a good tool to have if you keep working on cars.
About the PM friend request - no offense, but I'd rather solve things here in the forum. The whole idea is for other people to see this when THEY come across the same problem.
Its okay i like that idea.... okay well my car is now alive woot woot im happy now lol... i got a distributor from an h22 honda vtec it fit right in and with some timeing it started right up..... but...... now it seems to run slugish and slow on take off. The check engine light comes on now when i seem to get on it a little around 40mph and it when i turn my car off and back on its gone.... then it smelled like my cat was going but it has already been gone since iv had the car..... so can anyone tell me how to get it run back to normal....
I am betting your dist. has a worn bushing and that is your starting problem as the rotor is tearing up the cap contacts or is too far away from them depending on where the shaft places the rotor(it has to line up with the button in the center of the cap and the contact for each cylinders. I have never bought a dist for an Accord so I don’t know if you have to reuse any parts but it is easy to remove and replace. If you install it correctly it should slide right in if not you have the shaft a 180 degrees off. You should set the timing when you are done. On my Accord there is a jumper below the grove compartment you jump and then set the base timing.
Let us know how it turns out
pakalolo
Oct 28, 2013 02:06 PM
