1991 Honda accord lx blinker problems
Old Dec 23, 2014 | 12:14 AM
Had a similar problem on my 95 accord.
There are two grounds bolted under below the headlight under the bumper (IIRC) with several black wires going to it. Unbolt those grounds and clean the bracket and bolt. The pdf is for a 95 accord, but your 91 will be similar. They are labeled G201 and G301 in the attached pdf.
File Type: pdf
Old Dec 23, 2014 | 02:11 AM
Tyler Hollingsworth's Avatar
I don't think I've seen those on mine. my bumper was torn off when I got the car so.. Yeah could be the reason.. But I took the instrument cluster out had bad burnt spots on the circuit board so I clean it a little and got the oil and battery and seatbelt lights working but I will check for those grounds tomorrow
Old Dec 23, 2014 | 11:33 AM
Grounds G201 and G301 are located differently on a 91 compared to a 95.
G201 is located on the right side of engine compartment, on inner fender panel.
G301 is located on the left front corner of engine compartment, on inner fender panel.
Attached Thumbnails 1991 Honda accord lx blinker problems-ground-g201.jpg   1991 Honda accord lx blinker problems-ground-g301.jpg
Old Dec 23, 2014 | 12:33 PM
Okay I will check those out sometime when the rain slows down today
Old Dec 23, 2014 | 05:37 PM
Ok cleaned those grounds still nothing different. The only think that has helped is cleaning the instrument cluster circut board.. I think I'm going to try to find one of those localy for cheap I hope
ETH13
Feb 8, 2013 03:43 PM
Dead Zeppelin
Jul 13, 2012 08:36 PM
cmcconkey
Jan 16, 2011 03:51 PM
RR1775
Dec 3, 2006 12:36 PM
stokesdope
Aug 24, 2005 07:32 PM
