1995 accord lx head gasket repair steps and tips
Im having someone replace my headgaskets and i just wanted to know of all the parts that can be checked and replaced also during the headgasket repair. Also i was curious about theprocess of what the headgasket repair consisted of such as what needs to be done to fix this part because i read something about shaving headgasket before replacing.
OP - If you are not sure when the timing belt and that were last done - or if you are close to needing it done I'd do that as well.
I'd have the head "worked" while off. And by that I mean have the machine shop check the valves, seats, guides, ect. Of course be sure it is straight.
Last, "why" did the head gasket go? Yea it is a gasket and can fail after a long life but usually "something" helped it go.
Never seen that method? I've only seen the single plate but that is me.
I'd have the head "worked" while off. And by that I mean have the machine shop check the valves, seats, guides, etc. Of course be sure it is straight.
I'd probably done things differently if I had done more troubleshooting first.
thunder_x
Jul 9, 2007 11:57 AM
