1999 accord crank position sensor no signal
Old May 26, 2010 | 10:10 AM
dineromike1's Avatar
Default 1999 accord crank position sensor no signal
I'm workin on my buddys 99 accord and checked the code which is p1382 (crank position sensor no signal. Only # 1 cylinder is firing and 2,3,and 4 r dead. Changed crank sensor changed disturbuter.... Same ****! Put jumper harness from obd II to obd I w/ a civic sd computer and same ****! Narrowed it down to a short somewhere. Idk if this is a common problem on accords or what. Help me out please. I don't work on accords much so that's why I'm on here.
Old May 26, 2010 | 10:57 AM
I'm tryin to bypass it but need ecu wiring diagram... where can u find 1?
pondrun
Nov 8, 2021 09:40 AM
Pacman311
Sep 28, 2013 06:26 AM
Tyler Joyce
Sep 24, 2012 08:52 PM
argarcia86
Feb 23, 2012 06:49 AM
keefer
Jun 16, 2008 08:29 AM
