2001 Accord LX - AC clutch not working
Old Jan 2, 2013 | 12:00 PM
  #31
SirJohnIII's Avatar
Ok....Finally got back to the car....The A/C system is holding pressure just fine so I dont think that there is a leak....The fan and clutch work when I bypass the pressure switch so my guess is that the pressure switch is no good and should be replaced...any thoughts.
Old Jan 2, 2013 | 06:52 PM
  #32
This is getting long, which means I didn't re-read everthing. If you do a continuity test on the pressure switch....what does it show?
There should be about 5v to one side of the switch.....then if ac pressures are to spec...the 5v "flows" to the other side.
Attached Thumbnails 2001 Accord LX - AC clutch not working-6th-gen-ac-circuit.jpg
Old Jan 7, 2013 | 06:39 PM
  #33
SirJohnIII's Avatar
Switch reads as being open, it also has 5 volts coming in but none going out so since the system has pressure and holds pressure I figure the switch is faulty... What do you think?
Old Jan 8, 2013 | 05:41 AM
  #34
Agree as long as you're sure of system pressure. I remember something about a faulty pressure gauge.
I believe you will have to discharge the system to replace the pressure switch as there's no schrader vavle beneath the switch.
Old Mar 17, 2013 | 01:23 PM
  #35
SirJohnIII's Avatar
Bingo, I replaced the low pressure switch are then pressed the system back up along with additional PAG oil and it is cold as a new system.
Old Mar 18, 2013 | 07:39 PM
  #36
Thanks for the update....cold ac, nice
Old Mar 18, 2013 | 07:45 PM
  #37
Few things in this world are more satisfying than repairing your own ac and enjoying the chilled air.
thanks for followup
sheerrocko
Dec 4, 2013 08:08 PM
smh410
Jun 14, 2012 12:57 PM
boomman
Apr 4, 2011 10:20 PM
arunsam3000
Mar 6, 2007 01:40 PM
tamb
Jul 21, 2006 01:05 AM
