2007 Accord annoying noise
Old May 1, 2007 | 07:06 PM
musicmaniac
Default 2007 Accord annoying noise
I have a 2007 Accord EX-V6 with Navi with approx 2200 miles on it. Once my oil change is due I will bring it to the dealer to check it out but I thought I would drop a line in here and see if anyone else has had this strange noise.....Basically, when I'm coasting to a stop with my foot on the brake lightly I get this noise which sounds like a rubbing or clicking noise which sounds like itscoming from the right rear, When I'm in my driveway and put it in reverse and slowly back out I hear this noise also coming from the rear. Anyone else have something like this happenor know what I'm trying to get at it? I can't see it being a brake problem this early but who knows.
Old May 1, 2007 | 09:28 PM
sir_nasty's Avatar
Default RE: 2007 Accord annoying noise
It sounds like a bearing or brake issue to me but this is the first I've heard of it happening on an 07.... Unless you've got a rock or a bunch of dust from roads caught in there somewhere....
Old May 1, 2007 | 11:37 PM
Chiovnidca's Avatar
A creaking noise? Only at low speeds with light brake pressure? Possibly a warped rotor if yes.
Old May 2, 2007 | 06:50 PM
musicmaniac
I'll take this info into consideration, thanks...What I also noticed is if I'm inthe driveway and put the car into either drive or reverse and let off the brake, and the car is just rolling,going straight or reverse I hear the noise also. It's basically driving me nuts at this point because I have opened the trunk, put down the rear seat thinking maybe its something to do with that but to no avail.
Old May 26, 2011 | 01:20 AM
jattz02's Avatar
Default 07 accord rear noise..
I have got the same problem on my accord, around rear passenger side tire. Everytime i go over speed bumps, or pulling into drive ways. I even changed my control arm for that, but that noise isnt going away. Does anyone know how to get rid of it?
Old May 26, 2011 | 01:32 AM
I would inspect the brake pads to see if they need changed.
I would check the stabilizer bar end links to see if they are loose.
skoty
Jul 15, 2021 07:21 AM
lyndaglenn7@yahoo.com
Sep 12, 2014 08:00 AM
argarcia86
Feb 13, 2012 07:21 AM
posativJ311
Dec 17, 2011 11:09 AM
stina-wo
Mar 3, 2011 08:38 PM
