92 honda accord electrical questions.
Old Oct 1, 2014 | 10:54 PM
sarcasticook's Avatar
Default 92 honda accord electrical questions.
Hi guys
I'm helping a friend fix his car and most of it is pretty straight forward. But here are the problems. First one is that front corner lights don't work and all fuses are good. I have been reading info on the light switch but the tail lights do work. Second problem which may be related. There are 3 Orange plugs under the hood. One on each side of the engine compartment towards the front and the third is a larger one on the pass side near the firewall. The one by the air box has visibly damaged wires. My question is what system are they in and are theyconnected to the lights?
Some additional info:
I'm told the engine is straight from Japan.
I have not physically checked the bulbs, tried to repair the wires or pull trouble codes yet. We ran out time today.
Thank you in advance for any help and suggestions.
Old Oct 2, 2014 | 12:19 AM
What wire colors are going to the bulbs that do not work? Do the headlights and highbeams work properly? How about turn signals?
Old Oct 2, 2014 | 09:51 AM
The low beam lights work fine, not sure about high beams. The tail lights work and at least one of the turn signals work. This is all stuff i noticed last night as he was leaving. I already asked to check the rest of the lights. I will get some wire colors and more info for you soon.
Thank you.
Old Oct 3, 2014 | 06:12 AM
Turtlehead's Avatar
Orange connectors are for the ABS. Yellow connectors are for the SRS.
Old Oct 6, 2014 | 01:53 AM
Thank you turtlehead that is definitely helpful as well. I'm still waiting for my friend to have the time to come back. When he does i will post a pic to clarify the plugs and will let you guys know if i find the problem. Having issues in at least two different systems is gonna be fun. I already know I need to repair some of the wires in the harness with the orange plugs and few other spots. I'm just hoping this doesn't turn into a bigger headache than I can deal with.
Thanks again to both of you.
eze123
Jul 16, 2010 12:29 AM
SunshineSharlene
Jul 5, 2009 03:26 PM
foxytsula
Jan 15, 2009 07:59 PM
TRIGGA
Oct 19, 2007 01:57 PM
eddyfurukawa
Feb 13, 2006 03:15 PM
