'93 Accord lx won't start, Help Please!!!!
Old Mar 27, 2009 | 02:14 AM
  #21
cumminsman, you are talking about the main fuel relay.
Bad solder connections on MFR problems can cause the fuel pump not to get power, injector problems, and some other problems. I don't know if a bad MFR would cause the car not to throw a spark.
Old Mar 27, 2009 | 06:46 AM
  #22
In the Hondas that I have owned, the main relay has nothing to do with the coil, distributor, or spark. The only cause/effect would be if the main relay fails to supply power to the ECU itself. Then you get NOTHING.
Old Mar 27, 2009 | 07:58 AM
  #23
jsam's Avatar
Originally Posted by cumminsman
Okay, I am no mechanic, but this same thing happen to me. What I learned is that when this occurs and your check engine light does not go out it is a modul under the dash board. One guy said I needed to replace it and another guy (the guy that got the job) said he could just soder it and it is fixed. I don't know the name of it, but someone on here should know.
The ICM (ignitor) is located inside the distributor cap. It is not user repairable in my opinion.
Autozone has the equipment to test this module for free. If the ICM is bad, the CEL does not always light up.
The main fuel relay is located under the dash board on the driver side in '92/'93 Accord. It is repairable by re-soldering the leads. Autozone has NO equipment to test this relay.
kevozoomslbc
Apr 18, 2014 09:33 AM
BigDaddyJay07
May 4, 2013 10:51 PM
ItsMeAaron
Nov 1, 2010 08:18 PM
David Crevenston
Jul 11, 2010 11:11 AM
NuTech
Aug 15, 2006 09:03 PM
