'93 Accord lx won't start, Help Please!!!!
cumminsman, you are talking about the main fuel relay.
Bad solder connections on MFR problems can cause the fuel pump not to get power, injector problems, and some other problems. I don't know if a bad MFR would cause the car not to throw a spark.
In the Hondas that I have owned, the main relay has nothing to do with the coil, distributor, or spark. The only cause/effect would be if the main relay fails to supply power to the ECU itself. Then you get NOTHING.
Okay, I am no mechanic, but this same thing happen to me. What I learned is that when this occurs and your check engine light does not go out it is a modul under the dash board. One guy said I needed to replace it and another guy (the guy that got the job) said he could just soder it and it is fixed. I don't know the name of it, but someone on here should know.
Autozone has the equipment to test this module for free. If the ICM is bad, the CEL does not always light up.
The main fuel relay is located under the dash board on the driver side in '92/'93 Accord. It is repairable by re-soldering the leads. Autozone has NO equipment to test this relay.
kevozoomslbc
Apr 18, 2014 09:33 AM
ItsMeAaron
Nov 1, 2010 08:18 PM
David Crevenston
Jul 11, 2010 11:11 AM
