95 Honda a/c not cooling
Old Aug 15, 2012 | 02:47 PM
laheath's Avatar
Question 95 Honda a/c not cooling
The honda dealer replaced the heater control valve and thermostat, flushed the coolant and told me to have the a/c bled and checked for freon. I just did that at my neighborhood mechanic and he said I was 1/2 pd down on freon. But after that, I'm still not getting any cooling. What should I do next? Return to Honda or the local mechanic for what??
Lois
Old Aug 15, 2012 | 05:47 PM
This belongs in General Tech
Old Aug 15, 2012 | 07:17 PM
For cooling the compressor must be running. Look at face of compressor and see if compressor clutch plate is engaged and turning.
If not turning, then an electrical problem or mechanical problem that must be addressed.
If turning, then charge is low or expansion valve is defective. Hi/Lo system pressures must be obtained to determine what's wrong.
Old Aug 16, 2012 | 02:54 PM
laheath's Avatar
Red face a/c
Thanks for your ideas - I took it back out to Honda and it seems the cables that run from the dashboard button control are "stretched" and locked in heat position. So they moved it to the cold position and I'll deal with the cables later.
Old Aug 16, 2012 | 09:17 PM
If you need/want pic's on these cables you can download the manual and adjust these yourself. Sounds like the blend door needed adjustment. Or the **** has a broken shaft, trust me this happens.
Rilex
Aug 8, 2015 01:13 AM
HondaSpeeD98
May 2, 2012 10:24 AM
Golddoor
Aug 17, 2011 05:10 PM
adamc44
May 23, 2007 08:57 PM
blazedg
Jul 7, 2005 05:03 AM
