96 Accord LX (F22B2) - Seals Replacement with Timing Belt
Old Oct 18, 2011 | 08:46 PM
Replace the o-ring before going with a new oil pump and that...you should be fine
Old Oct 18, 2011 | 11:22 PM
partialresponse's Avatar
Originally Posted by tashier
When installing these seals, can they be installed too far? I tapped mine in until they stopped which is farther in then the ones that I pulled out. Just wondering if that's an issue or not? Seems the only way to get them in perfectly straight is to push them all the way in.
You cannot install them in too far. They will eventually bottom out. They should be inserted until they bottom out.
-Kofi
Old Oct 19, 2011 | 12:43 PM
tashier's Avatar
-Kofi
Thanks man.
So is the consensus with anyone else that the oil pump/balance gear sets don't develop leaks and need to be replaced with the timing belt? This is a car with 160k. Feedback from as many people would be helpful. It's just an almost $300 item that I'd like not to have to purchase. So far I have one person here that says no and a dealer that stocks them because they do leak. Not much to go on.
mclasser
Dec 26, 2013 03:06 PM
PinkFloridaFlamingos
Aug 27, 2011 08:08 AM
pelampe
May 3, 2010 11:47 AM
Tony1M
Apr 1, 2007 05:42 PM
