96 accord wiper issue
Old Nov 23, 2011 | 07:18 PM
painbird's Avatar
Default 96 accord wiper issue
i have a 96 accord dx and the wipers just won't turn off. is there a way i can just disconnect the motor for now until i can take it to get repaired or maybe do it myself?
thanks
Old Nov 23, 2011 | 08:54 PM
You can pull the #6 fuse in the fuse box inside the car. It is a 30 amp fuse for the wipers. It would be in the middle row and on the right hand side.
The problem could be the switch. That is pretty simple to take apart and check for problems. You can clean the contacts, then use some dielectric grease to see if that solves the problem.
Old Nov 24, 2011 | 01:02 PM
painbird's Avatar
Thank you for your help. How do I take it apart?
Old Nov 24, 2011 | 01:10 PM
In the Common DIY Threads sticky at the top of this section there is a link to a manual (I think it is labeled as a 94-which is the same gen as yours). Download that and it should help guide you thru the tests and getting to it.
Blueconnect
Aug 15, 2013 04:25 PM
95AccordOwner
Feb 18, 2013 03:14 PM
dcoperator
Mar 18, 2011 08:14 AM
reinventingaxlrose
Dec 1, 2008 11:47 AM
mahones
Oct 13, 2008 08:24 AM
