Brake pins
Old Feb 23, 2007 | 09:57 AM
tfunk's Avatar
Default Brake pins
Ichanged the brakes on my 97 Accord a few years ago and was wondering what kind of lube/grease to use on the pins? I have used some bearing grease that I use for my wheel bearings in my boat, but that seems to wear off after a 4-6 months and they start sqeaking. I have lubed them twice now, but the sueak comes back. I have ceramic pads and have put the red brake quiet stuff on the back of the pads, but I am pretty sure it is the pins that are my problem. Thanks!
Old Feb 23, 2007 | 12:44 PM
Default RE: Brake pins
You can find brake grease at places like AutoZone. It's relatively thick & gooeystuff, usually silicone-based.
Those pins have rubber boots. Are those boots OK?
Are you sure it's the pins making the noise? They barely move.
Old Feb 23, 2007 | 03:38 PM
wietgr's Avatar
anti-seize works fine aswell
Old Feb 23, 2007 | 05:29 PM
deserthonda's Avatar
non factory pads have a tendency to squeak more so than Honda pads ' also you might have to resurface the rotors ..
whycomputers
Sep 4, 2012 09:03 AM
kingofudupi
Oct 19, 2011 12:10 AM
driveguy
May 23, 2009 02:35 PM
wardykid23
Oct 9, 2007 11:48 AM
Sparco_racingVTEC
Dec 28, 2006 02:29 PM
