Common DIY and Info. Threads
Here is a list common threads referenced in the general tech help section by a lot of members on here.
I didn't put all of the DIY threads in here, and I am likely missing some useful ones.
Attn. Mods: I am locking this thread, but feel free to add links to it.
General Threads
Online Shop Manuals
https://www.hondaaccordforum.com/for...34/#post340068
CEL (Check Engine Light) Code Retrieval
OBD 1 ECU and TCU Codes
Set BASE idle 2002 & earlier
Timing Belt Tensioner Tip (1990-2002)
Coolant Temperature Sensors Detailed Explanation of Each Sensor
Automatic Transmission Fluid Change
Bleeding your clutch
Parts Compatibility
Honda Electrical Connector Terminal Replacement Procedures
Generation Specific Threads
4th Generation Accord (1990-1993)
EGR Port Cleaning
Rotor Over Hub Conversion
Wheel Stud Replacement
5th Generation Accord (1994-1997)
EGR Port Cleaning
FITV Cleaning
IACV Cleaning
ABS Bleeding
DIY – Repair: 1994 – 1997 Accord - Power door lock (actuator) buzz sound or cycling
6th Generation Accord (1998-2002)
EGR Ports V6
Knock Sensor
Clean your IACV (Idle Air Control Valve) | Honda Accord DIY
HVAC Codes
7th Generation Accord (2003-2007)
HVAC Diagnostic Trouble Codes
Easy way to test that interior Fan Blower Motor works (2003 – 2014 Accords)
Owner's Manuals 2004-2007
Checking blower-control circuit 2003-2006
Blower Motor Transistor Replace/Repair
Serpentine Belt Tensioner V6
8th Generation Accord (2008-2012)
Ventilation Fan Noise
https://www.hondaaccordforum.com/for...2-4l-i4-33793/
https://www.hondaaccordforum.com/for...-guides-33830/
https://www.hondaaccordforum.com/for...ictures-33778/
2008-2012 Accord Maintenance Guide 4 cylinder
9th Generation Accord (2013-2014)
https://www.hondaaccordforum.com/for...ned-off-52000/
https://www.hondaaccordforum.com/for...-scrape-52001/
How to disable Active Noise Control (ANC) while retaining Hands Free Link (HFL)
https://www.hondaaccordforum.com/for...08/#post342552
General Threads
Online Shop Manuals
Parts Compatibility
EGR Port Cleaning
EGR Port Cleaning
FITV Cleaning
IACV Cleaning
ABS Bleeding
EGR Ports V6
Knock Sensor
HVAC Codes
markus9175
Mar 27, 2009 10:35 PM
mjhenks
Jan 16, 2009 11:42 PM
