Details, details...lol Trans problem now
Old Dec 6, 2006 | 10:52 PM
huzzsaba's Avatar
Default RE: Details, details...lol Trans problem now
If its anything like the 94 model, you dont even need to raise the car.Simply turn the wheels to the right to give clearance to the drain plug. I just made sure the ratchet was nice and snug in the hole and gave it a nice wack and it came loose. let it drain and then fill.
My 94 took about 2.7 quarts.
Old Dec 6, 2006 | 11:57 PM
otherhonda
Is there no filter in the system?
Old Dec 6, 2006 | 11:59 PM
ohccord's Avatar
No filter.
Old Dec 7, 2006 | 07:51 PM
YeuEmMaiMai's Avatar
Do you get heat from your car? if your car's tstat is not working properly then it could cause problems it will cause the tq converter to unlock and lock. I had that problem in my 94 accord. it felt like it was going in and out of 4th but it was just locking and unlocking the converter. New tstat solved the problem
(car never reaches OT when it started getting cooler outside)
there is no user serviceable filter on the trans however it does have a filter.....
Old Dec 7, 2006 | 08:16 PM
sir_nasty's Avatar
ORIGINAL: deserthonda
tranny fluid should be checked with engine off,, level surface.......
as for the shifting issues,, replace thr tranny fluid as adviced use Honda ATF-Z1 as suggested ,,,,,,,,,,
if still no luck,
remove the shift solenoids at top of tranny and blow carb cleaner in the passage , if you have compressed air, blow into the passage as well. clean the metal screen of any debris, put all back together,, make sure that the connections are ok ,,no broken or loose wiring
Yep I'm slow some days... I spent to long checking fluid in military trucks and gave you instructions for how to check those without even thinking.... Sorry about that...
huntersdl
May 3, 2014 08:23 AM
njmodi
Dec 16, 2011 10:06 PM
dyeballer26
Mar 13, 2008 11:44 AM
bil6ly05
May 21, 2007 10:55 PM
nixalot
Apr 19, 2006 01:21 AM
