Dry Starts after oil changes??
Old May 2, 2013 | 09:43 AM
greg24's Avatar
Default Dry Starts after oil changes??
Ive been doing lots of research on changing my own oil, i saw that most wear comes from starting your car, ESPECIALLY after changing the oil because the filter wont be full of oil there isnt pressure as quick so it can wear out your engine bearings and other parts of the engine. How many of these dry starts can a car take before breaking??? or wearing out the bearings? How bad is the damage from starting your car after an oil change? and how many oil changes will it take before it ruins the bearings and what not.
Old May 2, 2013 | 10:58 AM
shipo's Avatar
All things considered, you're way overthinking this. Why? Because even with the dry starts (which can be at least partially remediated by pre-filling the oil filter with new oil), the engine will most likely outlast the rest of the car by many years.
Old May 2, 2013 | 12:15 PM
Read posting rules and don't post in DIY forum.
Dry starts probably don't hurt anything. If they did, there would be warnings and procedures to reduce damage.
Personally, I always try to reduce amount of engine running w/o oil pressure by starting/killing as soon as engine catches. Usually 2 cycles are enough to get oil pressure light to go off. I've had engines that knocked until engine oil pressure came up and developed the start/kill to reduce knocking.
Old May 2, 2013 | 01:01 PM
Roader's Avatar
And it's really not "dry"; there's a film of oil left on pressure lubricated parts after an oil change. Bearings might knock for a few seconds but it's not metal-to-metal contact.
Old May 2, 2013 | 01:24 PM
greg24's Avatar
if its not metal on metal then what makes the knock noise?
Old May 2, 2013 | 01:27 PM
Dr. Drivability's Avatar
some old school mechanics would say to disable the ignition system by removing the coil wire, grounding it and cranking till the idiot light went out, or the gauge registered pressure...of course this is near impossible on todays engines...
Old May 2, 2013 | 04:25 PM
Roader's Avatar
The bearings. Normally they're riding on a nice, thick film of oil. No oil pressure means no thick film of oil. But there's still a thin film for the several seconds it takes to fill the filter and build up pressure.
Old May 2, 2013 | 04:48 PM
EXV6NIGHTHAWK's Avatar
I think, if you ran the engine just before draining the oil, like you are supposed too, and didn't take forever to finish refilling, there would be enough oil left on the bearings and internals, that the "dry start" would be negligible. Seems to me, a dry start, after the car has been sitting for days, or even just overnight, would be more harmful than the start after an oil change.
Old May 2, 2013 | 05:03 PM
valvelash's Avatar
Way over thinking this. Use quality oil and filter, change it often and go spend the energy & time on things that are way more important. all will be fine
crispin
Nov 16, 2011 10:23 PM
custy
Apr 22, 2008 10:38 AM
triplej
Apr 13, 2008 01:00 PM
cindjo717
Sep 10, 2007 01:17 PM
scandalus
Jul 11, 2006 04:23 AM
