Sponsored by:
Sponsored by:
Head Cracked
Old 03-10-2011, 05:24 PM
rwyatt80's Avatar
Default Head Cracked
So here is the deal...
After at least 5 attempts to resolve my oil leaking issue, I dont know what else to do. I have a 96 accord lx. Oil seems to seep into where my spark plugs are, but it only afftects two of the four. i have changed valve cover gaskets and o rings (several times) and have even replaced the valve cover. I am convinced that something maybe warped or cracked, but how do I know what to look for to rule out those two things
any help is appreciated
Old 03-10-2011, 05:29 PM
So you changed the valve cover gasket and the upper seals.
Did you remove the rocker assembly and replace the lower seals? They are #19 in the picture below.
Old 03-11-2011, 06:10 AM
rwyatt80's Avatar
The only thing I have changed is the valve cover gasket and the O rings. If the rocker arm you are talking about reqires me to take off more than just the valve cover, then I know I didn't hav. e those rings done
Old 03-11-2011, 11:59 AM
There are another set of seals. There is a writeup in the DIY about oil in spark plug tubes.
Google wYU8qtPzQOY
The first hit is an excellent video on how to replace the lower seals.
Good luck.
Old 04-01-2011, 09:55 AM
rwyatt80's Avatar
So, after much research, the cluprit is a crack in the tube where the spark plug sits. after my mechanic and I took the cover off and really looked at it, the crack explains my problem. SO, I have decided to replace the entire engine. Why you may ask?? Well, with over 300,000 miles on it, I decided it maybe more beneficial to replace the engine as opposed to just the head. I want to thank you for all your help in this matter. I am learning more and more about my car everyday..thanks!!
My Honda
03-11-2014 02:20 PM
miami honda
07-11-2007 05:32 PM
dodins
03-18-2007 08:10 PM
kjinpb
08-19-2005 10:42 PM
Quick Reply: Head Cracked
