I need to arm or enable the factory alarm for 98 Accord Ex
Old Oct 14, 2006 | 07:26 AM
ckebottle's Avatar
Default RE: I need to arm or enable the factory alarm for 98 Accord Ex
ORIGINAL: ajluu
I press the lock button twice and it does honk. But when I use my key to open the door manually without unlocking the alarm does not go on. I want to turn the alarm on but don't know where to start. The LED light on the dock flashes when I lock using the remote . Also, the trunk button does not work either. I press and held down the trunk but it it does not pop up. Do you have to enable this too?
On my 99 ex I had to program the remote. For the trunk, just keep pushing it constantly and eventually the trunk will pop open. Holding it didn't work for me, but constantly pressing it did. Hope that helps you out.
Old Oct 15, 2006 | 04:16 AM
YeuEmMaiMai's Avatar
to test your alarm all you have to do is leave you window down about half way, wait about 1 min for the system to arm, reach in and unlock the door and then using the outside doorhandle OPEN THE CAR DOOR. The alarm should sound.
ckebottle
take your remote apart and wipe off the circuit board on the side that has the buttons and then reassemble. That should fix the problem, if not replace the remote.
lecompte51
Jul 3, 2013 01:38 AM
prkarpi
May 30, 2009 02:58 AM
getatjbrown
Nov 19, 2007 11:16 PM
rEEd E.
Aug 12, 2006 04:06 AM
wu4607
Mar 24, 2006 11:17 PM
