Installed a trans oil cooler now I got several dash lights
Old Sep 29, 2025 | 08:00 AM
cris's Avatar
Default Installed a trans oil cooler now I got several dash lights
‘07 Honda Accord SE V6 (Non-Hybrid)
I installed a Tran oil cooler and replaced the trans filter that’s on top but once I put everything back together beside the intake and went to turn the car on it was running just fine then I was putting the intake back on. Then suddenly after maybe 5 minutes or so, it threw a check engine light (codes P0113&P0118) which I touched nothing electrical beside a ground strap which I disconnected the battery before touching and both sensors are brand new…
It also throws VSA light and a triangle with an exclamation within along with the Temp gauge claiming the vehicle is overheated from a cold.
The car runs fine, no jerks, shudders or weird vibrations beside a “whooshing” type sound coming from the side which I assume the water pump probably went or going out but theirs no leaks of any sort.
eyezauuh
Jul 18, 2021 07:50 PM
no.never
Apr 9, 2014 05:16 PM
lethalaudio
Oct 13, 2011 02:29 PM
macdadflex
Oct 13, 2008 07:11 AM
fryhead
Feb 16, 2006 04:04 AM
