No speedometer
Old Jul 10, 2012 | 07:17 AM
Michael Kozura's Avatar
Default No speedometer
1991 Accord no speedometer then S light blinks the check engine light comes on......help. thanks
Mike Kozura
Old Jul 10, 2012 | 08:10 AM
Please post questions like this in the General Tech section, I've moved this one for you.
First thing you need to do is get the codes from the ECU (CEL) and the TCU (D4). See this for help: https://www.hondaaccordforum.com/for...threads-40780/
Sounds like an issue with the VSS but you want to get the codes to be sure and not go on a guess.
EDIT: I now see that you did post this question in this section as well. I deleted the dup questions/posts
Old Jul 10, 2012 | 08:35 AM
Thank you
Mike Kozura
Old Jul 10, 2012 | 10:56 AM
Anytime, let us know how it goes
Old Jul 10, 2012 | 06:15 PM
OK Man I got
ECU #17 VSS - speed sensor
TCU #4 vehicle speed sensor open or shorted - no singnal from speedometer
Mike Kozura
Old Jul 10, 2012 | 06:22 PM
Well that goes with what I was thinking.
You can do some more tests or find a used/new VSS and replace?
Old Jul 10, 2012 | 06:26 PM
I already have one coming thanks...... I got it before I found this forum, Local parts stores were 100.00. I got one on E-Bay for 10.00...... I hope it works if not heck it was only ten bucks....lol
Honda VSS Vehicle Speed Sensor - Brand New | eBay
Mike Kozura
Old Jul 12, 2012 | 05:13 PM
Thank you...Thank you...Thank you... just changed th VSS and all is good...and my sixteen year old (whos car it is) got a lesson on getting little bolts out of little places, when you drop them....lol.
Now I have to start a idle threed....sometimes it's good sometime it's not....lol. still trying to gather more info on when it does it..
Thanks again
Mike Kozura
Old Jul 12, 2012 | 10:16 PM
You're welcome, you're welcome.....our pleasure
A '91 with idle issues. Again do nothing until you know.
All tune up items need to be checked (cap, rotor, plugs, inspect wires) if you are not sure of their age.
A good TB (throttle body) cleaning never hurts.
From there, the IAC, FITV and the Air boost cleaning/adjustment would be on my list.
Try to get the "situation" when this happens, as you said, and it might help narrow down things.
Good luck
Old Jul 13, 2012 | 06:06 AM
Thanks....speaking of the TB we had the air duct off and there's oil at the TB.....not a lot but oil....it seems to be sucking it from the little vac line..... but not sure. I wiped oil from the TB with my finger but didn't clean it good. Now today cold or hot it seams to idle ok....about 850 or so thanks
cochre
May 10, 2012 11:58 AM
UnitedAuto
Apr 18, 2011 10:44 PM
darryltravis
Apr 25, 2006 01:26 AM
cclc31
Oct 25, 2005 09:27 PM
cbriley3
Oct 23, 2005 11:04 PM
