Passenger Power Window Suddenly Stopped Working
Old Sep 6, 2012 | 09:56 PM
MyFirstAccord's Avatar
Exclamation Passenger Power Window Suddenly Stopped Working
I have a question for anyone that could help me out. I just got my first car a few months ago, a 96' Accord EX 2-Door Coupe with a VTEC. I love it dearly, and it's a little rough around the edges but I've been slowly fixing little things here and there.
Anyway, a few days ago I took off both the driver and passenger side door panels. On the driver's side there was a hole in the armrest from the plastic breaking, so I figured I might as well take off the passenger side to reinforce it before it breaks also. So I took them off to fix both of them, and I have had to drive it a few times with the door panels off.
I plugged in the switches so I could put the windows down while I drive, and I noticed that the passenger side window doesn't work anymore, though they worked perfectly before I took the door panels off. It doesn't work from the driver's side switch, or the passenger side switch; doesn't make noise, clicking, nothing while pushing the switches. Driver's side and everything else still works perfectly. Not sure what might be wrong, or even how to troubleshoot it as this is my first car, so I'm kind of new to working on cars.
Sorry for the very long post, but if you read it to this point thank you very much. If anyone has some advice, I'd appreciate hearing your ideas and thoughts.
Old Sep 7, 2012 | 06:27 AM
UhOh's Avatar
Originally Posted by MyFirstAccord
... so I figured I might as well take off the passenger side to reinforce it before it breaks also.
You'll think I'm poking at you, but not.
In future ... if it's not broken, don't fix it.
Old Sep 7, 2012 | 07:20 AM
I agree, I usually won't mess with stuff that works fine until it stops working completely, but the way I am repairing the door panels is a long process, and I figured it would be easier to do both at once rather than spend a week on one, and then a few weeks later a week on the other when it finally gave out. Upon taking the Passenger side off (the non-broken panel) I found the plastic under the armrest was cracked and split along the length of the arm rest, so it was only a short matter of time before it fell through also.
Old Sep 7, 2012 | 10:13 AM
Make sure the main switch on the driver's side master switch was not inadvertently switched off. See attached pics.
Attached Thumbnails Passenger Power Window Suddenly Stopped Working-main-switch.jpg   Passenger Power Window Suddenly Stopped Working-main-switch-narrative.jpg
Old Sep 7, 2012 | 11:04 AM
Thanks a ton Redbull, this was exactly the problem. I feel a bit stupid for not thinking to check this, but I'm glad my window works again! Again, thanks a lot!
jrberton
Jun 25, 2010 10:13 PM
jmtdaddy
Oct 19, 2009 09:41 AM
jmalek
Feb 24, 2009 11:45 AM
DrBones
Oct 13, 2006 07:05 PM
aceracer__
Jul 19, 2006 04:04 AM
