Question about 90 accord? PLEASE HELP
Old Aug 29, 2009 | 03:15 PM
90AccordCoupe
Default Question about 90 accord? PLEASE HELP
Hello, i have a 1990 honda accord EX 2 door when i went to start it one day it would not start i hit the gas it started the next day i went to start it would not start for nothin but did turn over just wouldnt start so i checked the spark plugs one had a bunch of oil on it and the others had a little bit on them so i wiped the oil out the wells and replaced the valve cover gasket, spark plugs and spark plug wires and now i have nothing no turn over no start nothing. i have the spark plugs goin 1234 from right to left and to the distributor goin 1342 from right to left. any help is appreciated.
Old Aug 29, 2009 | 06:31 PM
If no starter sound (loud click) and no starter turnover, first problem is to determine if starter is faulty or battery. Usually, it's the battery or the battery connections preventing good current flow. Clean both battery connections carefully.
If that checks OK or doesn't cause the starter to work, check the voltage at the Blk/Wht wire at the starter for 12v when keyswitch is turned to Start. If no voltage the keyswitch assy is bad and must be replaced.
Once you have the starter turning the engine over, you may have another problem; loss of fuel or spark, but starter first.
Old Aug 31, 2009 | 08:13 AM
Distributor terminals are in a circle. What do you mean 1342 from right to left? Sounds like firing order is messed up.
Still, if it doesn't turn over, that's a problem with the starter which has nothing to do with firing order.
esan805
Mar 29, 2012 02:33 PM
art vandelay
Aug 2, 2010 09:29 AM
mamtsberg
Mar 17, 2010 09:15 PM
BIGWILBO
Apr 5, 2008 07:57 PM
cenkaetaya
Jul 16, 2006 08:56 PM
