Synthetic oil or not?
Old Apr 20, 2017 | 08:05 PM
The Toecutter's Avatar
I know I'll probably get caned or something here, but if you have an Automatic Trans, use ONLY Honda ATF in it.
Old Apr 21, 2017 | 07:14 AM
shipo's Avatar
Certainly not from the likes of me.
The thing about ATF is different vehicle manufacturers design their transmissions to expect a very specific coefficient of friction (COF) in the ATF; regardless of the quality of the base-stock oils used for the ATF, if the COF is incorrect, the internal clutches will either grab too quickly (too high of a COF) or too slowly (too low of a COF), either way, a premature failure of the transmission is a matter of "when", not "if".
Long story short, unless a non-Honda ATF states it is certified by Honda to be 100% compatible with the Honda ATF (I don't believe there are any), then the ONLY fluid one should use in one's Honda automatic transmission is Honda ATF.
jasonan
Aug 28, 2009 11:26 PM
tran89
Jan 8, 2007 09:00 PM
newaccord99
Jul 18, 2006 08:27 AM
Andyf
Jul 7, 2006 11:33 PM
albertgarrido
Feb 27, 2005 03:27 PM
