Timing Belt to Gear Conversion???
Old Feb 4, 2008 | 01:37 PM
jefe525
Default Timing Belt to Gear Conversion???
I am a former gearhead of AMC and International engines. Both of those have timing gears and not belts...your maintenance intervals are infintely longer with gears. I know on some other vehicles, there are conversion kits available. Has anyone ever heard of a conversion kit for my 2001 Accord EX V6?
Once again...timing belt to gear (driven) conversion.
Any help and info would be appreciated.
Thanks,
Old Feb 4, 2008 | 02:45 PM
00AccordLX5spd's Avatar
Registered User
Default RE: Timing Belt to Gear Conversion???
I've never heard of it, but it would be great if they had one. The 2003-2007 4cyl models had timing chains instead of belts, but the v6 still has a belt. I am unaware of the 2008 models as to whether they use belts or chains.
Old Feb 4, 2008 | 03:18 PM
falkore24's Avatar
Aren't gears for pushrod engines? I've never seen an overhead cam engine with a timing gear.
Old Feb 4, 2008 | 04:58 PM
sir_nasty's Avatar
ORIGINAL: falkore24
If you've seen an 03-07 Accord you've seen an OHC with timing gears...
Old Feb 4, 2008 | 10:30 PM
BlkCurrantKord's Avatar
Not possible unless you got someone to make you a custom cam, crank gear, chain, then figure out how all the sensors that read off the crank would get their input.
john_pyro
Aug 4, 2019 05:06 PM
ss485
Feb 23, 2011 08:18 PM
hac2000
Sep 17, 2010 09:06 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
