Transmission solenoid or do I need a new tranny?
Old Jan 12, 2015 | 06:27 PM
djkurious's Avatar
I'm curious what the year of the car is...
Old Jan 12, 2015 | 07:01 PM
Reading "between the lines".....a 98-02 Accord.....but at the same time if the OP could confirm this is would be nice.
Old Jan 12, 2015 | 08:54 PM
robbierob02's Avatar
Well I got around to pulling the solenoid just a little bit ago and the screen was clean and all and again I applied power and I can hear the clicking better but still the opening click isn't quite as loud as loud as when it closes. And is the pin inside the body of the valve supposed to move when I put power to it? I'll try to get to changing the A/T fluid this weekend and see if there's any improvement
Old Jan 12, 2015 | 08:56 PM
Sorry guys it's a 2001
Old Jan 14, 2015 | 07:22 PM
Sorry, these start to run together after a while....didn't go re-read the whole thread.....I think you have a used trans already.
Pull shift c from it and compair the sound. To me you might have a weak shift C there is a resistance test you can do but I have found that can change with temps.
Old Jan 15, 2015 | 03:23 PM
Just to be sure do you mean pull shift solenoid B to compare with shift solenoid C? Just wanna make sure..
Old Jan 16, 2015 | 07:26 PM
  #17
Sorry, went back and re-read this, I had you confused with another poster.......that poster already had a junk yard trans.......so I confused myself and thought you had another "shift c" to compare the two....my bad.
Yes there should be some movement in the "valve" when power is applied and released.....it is small so a "feel" might be better than trying to look at it.
It is hard over the internet to say how "loud" the click should be. I hate to suggest spening money without more testing but a used shift c from a JY might be an option......if nothing else pull one from the yard and before you leave put power to it and compare (in your head) that to the one you have in the car.
Old Jan 17, 2015 | 10:54 AM
  #18
Well the weekend is here so I'm gonna try a fluid change and see if there is any improvement.
As far as the shift solenoid "clicks" there is a noticeable difference but also when I pulled the solenoid I did measure the resistance again and it was 17 ohms compared to 15.5 ohms when I tested it when it was still on the tranny with the engine warm.
Old Jan 17, 2015 | 11:49 AM
  #19
"C" is starting to sound like it is not doing the "job". Again I hate to suggest spending money on something that I can't be sure of.
A walk through a local bone yard and looking for a 6th gen Accord, you can pull another one and compare the resistance....click to the one you have
bigtex
Feb 21, 2018 11:08 AM
Clevor
Mar 26, 2014 01:31 PM
tobybul
Dec 17, 2013 02:53 PM
tranwreck
Apr 30, 2009 09:27 AM
