Well I messed this up..
Old May 30, 2012 | 03:57 PM
GoneHonda's Avatar
I Called a local import parts store that carries all the old stuff that I need in stock, he has 10+ of those studs in stock! And yea 3 buck minus my 10% discount for being a regular customer Thank you all! I will let you know how this turns out!
Old May 30, 2012 | 07:32 PM
Roader's Avatar
Originally Posted by GoneHonda
I was really hoping that this forum was going to be different then the other ones out there...
It is much more civil here than at the other forums. My guess is it's the product of the average age.
Old May 30, 2012 | 09:08 PM
EXV6NIGHTHAWK's Avatar
I used to do a lot of these (nightmares). If the studs were broken flush with the engine, I would have to tack-weld a washer on the stud through the hole, then tack a nut on top of the washer. They always came out, but sometimes it would take a few tries. Of course these blocks were out of the car, but I would get some blocks with 7 or more studs broken in them. It's like they broke them off on purpose. I have never used any other method to get them out, so I can't say if anything else works. Good luck
Old May 30, 2012 | 09:42 PM
GoneHonda's Avatar
Default well fixed
I ended up using a thread cutter and the old nut went on tight as can be... Got everything but the belts and PS pump back on. FIXED THANK YOU ALL!
6genex
Sep 28, 2007 01:38 PM
zillachord
Jul 25, 2007 11:43 PM
YeuEmMaiMai
May 30, 2007 01:44 PM
sir_nasty
May 9, 2007 09:27 AM
YeuEmMaiMai
Sep 21, 2006 12:55 AM
