91 accord VSS question
Old Jul 2, 2015 | 10:39 AM
  #41
Blastingas10's Avatar
Hey guys just thought I'd provide an update.
So the problem is ongoing. It's been in the shop for a week now and the guy got everything wired up correctly, according to the diagrams. He was gonna charge me 200 for that. He said someone really did a number on it and really screwed up the wiring. But after he completed that the car wouldn't start. So now he has to investigate that issue. This has been a real pain and inconvenience for me. I trust the guy I think, he seems to be honest but if the car isn't starting now I don't know how correctly his wiring job could have been done.
Old Jul 3, 2015 | 08:00 AM
  #42
Thanks for the update.
Hope the starting issue is a simple fix.....working in that area of the car, I'd re-check the ground on the t-stat housing....it is the main ground for the ECU so if it is not on/loose it will cause all kinds of issues.
Old Jul 15, 2015 | 12:11 PM
  #43
Got Another update. Believe it or not this thing still has not been fixed. Been in the shop for 3 weeks now. The mechanic is telling me he believes when this thing was wired improperly that it caused one of the componets in the distributor to short out and thats why its not starting. hes recommending that we replace the entire distributor.
How does that sound? I ask because I dont know how much faith I have in this guy.
Another update here: so I mentioned the thermostat housing ground to the mechanic and he said he would look into it. So sure enough he said the ground is not there. So he's going to go back through and attach the ground. Here's to hoping that's the problem. Thanks for pointing that out poorman.
Old Jul 16, 2015 | 10:42 PM
  #44
It sounds like the mechanic is possibly throwing parts at the car. What evidence does he have that the distributor is bad? Do you have no spark? Is the ECU throwing any codes?
Old Jul 18, 2015 | 07:28 PM
  #45
He said he's going to test the distributor some more. He fixed the thermostat housing ground and that didn't fix it. I don't believe there are any codes but I personally haven't checked. I'll have to go up there and do that myself.
According to him it's not getting a spark. Since it all started with some electrical wiring work he seems to be understand the impression that it's an underlying electrical problem or ecu problem, which if it is he advised me that it might not be a bad idea to throw In the towel because it could be a very costly repair.
sa2ms7on
Feb 23, 2012 11:06 PM
oma93
Jan 23, 2008 12:09 PM
comptoncarl
Feb 8, 2007 03:04 PM
JWW512
Jul 23, 2006 01:04 AM
cbriley3
Oct 23, 2005 11:04 PM
