94 EX coupe will not turn over
Old Feb 19, 2012 | 08:00 PM
spikey1566's Avatar
the only code mine was droppin was 4L and 1s. looks like it is 41 which was Primary oxygen sensor heater. would this have that effect after awhile?
Old Feb 19, 2012 | 08:32 PM
A code 41 shouldn't cause a starting problem.
The timing light is pretty simple to use to verify spark. Just connect the light to the battery. Then hook up the induction pickup on the spark plug wire. The light should flash if you are getting enough spark.
If you have a working vehicle, you can try the timing light on there to get a feel of how it works.
Old Feb 19, 2012 | 10:48 PM
spikey1566's Avatar
ok cool. ill try the timing light out tuesday when i get off work. i have another 94 Accord that is running.. thanks for the help. ill update then.
Old Feb 20, 2012 | 07:06 AM
In spite of the instructions for the timing light ("connect to the #1 plug wire)... Connect the pickup to all 4 plug wires one at a time. You're checking whether each plug has a good-enough spark.
When you actually use the light to time your engine, you'll use only the #1 wire.
Old Feb 21, 2012 | 06:28 PM
spikey1566's Avatar
Time for the update. Turns out it was a fuel issue. Fuel isn't supposed to be crystal clear I don't think. Lol. Put new fuel in it. Runs like a champ. Haha. Thought too much into that one I guess.
Old Feb 21, 2012 | 08:16 PM
Yea, the easy stuff sometimes fools us.
Old Feb 21, 2012 | 11:29 PM
  #17
spikey1566's Avatar
Yeah got her running, then died again. looked through the firing system, yeah the rotor button was burnt up. Got it swapped and running again. God too.
bcasey
Feb 23, 2013 06:10 PM
lecola
Oct 12, 2012 03:28 PM
ds125
Jan 31, 2012 01:50 PM
neub57
Oct 28, 2009 01:09 PM
PAY1920
Oct 20, 2007 08:11 PM
